Results 1 to 10 of 12
Thread: Jaguar X Type 2.0 Diesel GUIDE to: Starter Motor Change
    Jun 2008
    anyone changed out there starter motor and what was the best way as not a lot of space to remove . i know it can be done in less than one hour but how i would like to know thanks .
    Senior Member BuckMR2's Avatar
    Mar 2006
    Re: starter motor xtype 2.0 diesel
    Starter Motor 2.0L Diesel
    1)Disconnect the battery.
    2)Remove the air deflector.
    3)Disconnect the vacuum pipes from the vacuum solenoid valves and the vacuum reservoir.
    4)Disconnect the vacuum solenoid valves electrical connectors.
    5)Detach the wiring harness from the vacuum solenoids and vacuum reservoir mount bracket.
    6)Remove the vacuum solenoids and vacuum reservoir mount bracket assembly.
    7)Detach the wiring harness retaining clips from the wiring harness support bracket.
    8)Remove the wiring harness support bracket.
    9)Detach the starter motor.
    10)Position the starter motor to provide access to the starter motor cables.
    11)Remove the starter motor solenoid cover and electrical connector retaining nut.
    12)Remove the starter motor by removing the starter motor electrical connector retaining nut.
    Install is the reverse of above
    Tighten to 12Nm
    Tighten to 6Nm
    Tighten to 25Nm
    Tighten to 23NM
    BuckMR2
    http://i71.photobucket.com/albums/i1...MR2/sigggy.jpg
    Rear Entertainment , 2012 Nav
    DPF removed, EGRs deleted,
    kitchen sink...
  3. Thanks thedebs53 thanked for this post
    Senior Member cerberus1983's Avatar
    Aug 2007
    Quote Originally Posted by BuckMR2
    Sorry for dredging up an old thread guys but does anyone have any diagrams of how to change this out as im not that good with just written instructions
    Many thanks in advance
    Conor
    Jul 2010
    Nice one Buck, will make a note of the info sure to come in handy one day.
    Geran
    Jaguar X Type 2.0ltr sports estate
    Mitsubishi Pajero 2.8TD SWB yep the EGR is blocked
  6. #5
    Mar 2006
    Quote Originally Posted by cerberus1983
    Conor
    Above post edited to include diagrams and torques for retightening,hope this helps
    BuckMR2
    kitchen sink...
  7. #6
    westville
    Guest
    The Buckmeister strikes again
  8. #7
    Aug 2007
    Buck it is not said enough....
    YOU ARE A LEGEND!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9. #8
    Mar 2006
    Its all just info from the JTIS, many on here have them
    BuckMR2
    kitchen sink...
  10. #9
    westville
    Guest
    Yeah but not everyone takes the time and trouble to help like you do
    If there were an award for most helpful poster you would get my vote
    Keep it up
    Aug 2012
    Just wanted to say I followed this guide and managed to clean out the Starter Motor which was gunged up... Hopefully we get a few more months out of it before having to replace Thx again for your instructions... might I just add that these are "as seen from under the front of the car" oh and yeah what a helluva place to stick it!!! Thanks Jaguar! :P Seriously though, that's me used this site twice for things that would have cost me a fortune probably, so great job guys
