Page 1 of 30 1234511 ... LastLast
Results 1 to 10 of 293
Thread: EGR Removal and Cleaned (with photos)
    Mar 2011
    Essex
    Hi well i finally cleaned my EGR it today (pat myself on the back)
    heres a step by step with photos ........
    first of all you will need lots of these ......
    remove engine cover
    the EGR is located bottom left of the photo next to the air box
    heres a closer look at the EGR
    first thing to do is to remove the air box, so i removed the air flow tube (mine have tap screws to hold them in place) your should clip off
    then i unplugged the 2 connectors plugs on the air box
    then unplugged the MAF plug
    once all unplugged you can lift the box up (with a little tug)
    then once thats out of your way your able to get to the nut underneath (i used this spanner) (size 10)
    i made up a tool to get to the top bolt of the ERG witch is on the top far side lol
    i used a small screw driver to get to the ring tie
    i just pulled the little rubber tube off the EGR the pulled it out
    heres what i found .......
    i used some brake cleaner spray which done a good job and old cloths
    its getting cleaner ......
    then i put it back on (dont forget to put the rubber tube back on)
    the replaced the air box and connected all the plugs back on
    JOB DONE
    it took no longer then an hour and im a complete novice
    http://i201.photobucket.com/albums/a...P1000905-1.jpghttp://i201.photobucket.com/albums/a...IMG_2078-1.jpg
    Jaguar x-type 2.0d silver 2004 (53 plate)
    WE ARE ALL PRISONERS OF TECHNOLOGY !!!
    Mar 2011
    Essex
    Re: EGR Removal and Cleaned (with photos)
    i will be doing it all again soon but next time im going to clean the mainfold as well
    Oct 2010
    how many miles has your car done and have you noticed any difference?
    Are we human or are we dancer?. My sign is vital, my hands are cold. ...
    Jan 2011
    Good guide! I'll be giving mine a go within the next few weeks. It's not running too badly, though a little sluggish to start when hot. My main problem is my mpg average is quite low. I can manage 45-46mpg driven carefully on the motorway, when others can get over 50.
    Dec 2010
    Kings Lynn, Norfolk
    nice guide will come in useful in future
    Ex owner of
    XF-S 3.0 V6 275bhp Portfolio with a few nice extras Polaris White 20" Draco black rims Tinted windows and a few interior LED's
    X Type 2.2 Sports Premium estate in liquid silver with black leather/alcantara and carbon trim
    Apr 2011
    Well done for being brave and getting on with it
    Looked almost as mucky as mine with 93k on the clock.
    Mar 2011
    Essex
    Quote Originally Posted by JULES_525
    It's done 124000 miles (I've not had it long)
    I have not drove it properly since I done it, only up the road and back, I mainly done it to see if it improved my mpg as it was running ok (as far as I'm aware) I'll keep you informed on how she goes
    Swindon
    If this is inside of your engine, just think what is inside of you
    Mar 2011
    South Wales
    I'd really think about cleaning the inlet manifold as well, mine was really coked up when I took my egr off and its an easy job once the egr is off.
    2005 X-Type 2.0D S, 2008 Grille, MK4 Astra front splitter
    Senior Member Fluffball's Avatar
    Jul 2010
    Surrey/Kent Border
    Top Notch work. Thanks for the photos.
    http://i848.photobucket.com/albums/a...trip_1_h65.jpg
    Current: X-Type 2.2D SE Auto
    Past: Rover SD1 2.6 VDP Auto, XM 2.0 Turbo Onyx Auto, XM 2.0D Turbo, Omega 2.0, Austin 1300 TC GT plus others
