Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Appalling Radio
    Senior Member Tym's Avatar
    Jan 2010
    Lancashire
    Appalling Radio
    On my old diesel estate, the radio reception was great. This one's rubbish. Crackly - poor signal.
    Has anyone had this problem on a petrol estate and if so - how did you fix it?
    Tym (0%)
    55 Reg 2.5 X-Type JT2, Radiance1975, Touch Screen, Stone Leather, Heated Seats, Heated Screen, 2012 Sat Nav, Cruise, Parrot BlueTooth, *my own brand* tracker :GRIN:
    http://i835.photobucket.com/albums/z.../bungy_sig.jpg
    westville
    Guest
    Re: Appalling Radio
    Tym
    There have been a few problems with the aerial connections failing under the roof lining at the base of the device - there have been recent posts about that (incl some pics) which may assist - I think forum member prisoners did some stuff which I know you can find.
    Jan 2010
    Lancashire
    Re: Appalling Radio
    Every helpful - thanks Jim...
    Tym (0%)
    Oct 2010
    Aberdeenshire, Scotland
    Re: Appalling Radio
    If you are going rummaging in there between the roof and headlining I strongly recommend some latex/vinyl gloves!
    The back of the headlining is a fibreboard type material and it will leave you itching like mad if you have nothing on your hands - I found this out the hard way after replacing the aerial on my estate!!
    Jan 2010
    Lancashire
    Re: Appalling Radio
    Good advice! Thanks!
    Tym (0%)
    Jan 2010
    Lancashire
    Re: Appalling Radio
    Update: Seems better now, but I need to drive around to test the "blind spots" I'd encountered.
    Here's what I did...
    Remove the black rubber seal:
    Remove the two side panels. Be careful of these little beggars as they're very brittle when old (like me!!):
    Remove the dog guard clips:
    When removing the head lining, be careful as there's a big clip holding the middle up. It's a beggar to get off and I just separated it from the head lining. It actually moves towards the back of the car.
    The antenna connects into two of these (black with pink plug, and the red/blue):
    Undo the 22mm nut holding the base to the roof...
    and remove
    Undo the two small phillips screws to expose the innards of the base:
    My particular problem was these broken contacts which I've soldered back on:
    Reverse the procedure for refitting, then enjoy your radio...
    Tym (0%)
    westville
    Guest
    Re: Appalling Radio
    Nice one Tym - gonna link it on the How To Guides sticky?
    Jan 2010
    Lancashire
    Re: Appalling Radio
    If I knew how...
    Tym (0%)
    westville
    Guest
    Re: Appalling Radio
    Quote Originally Posted by Tym
    If I knew how...
    Done it for you - HERE
    May 2011
    London
    Re: Appalling Radio
    anyone know where its located on a non-estate ver, because i have a similar problem (probably not too bad), but my radio stations are often crackle a little
    Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety - Benjamin Franklin
