Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 78
Thread: HOW TO CHANGE YOUR DASHBOARD LOOK (WITH PHOTOS)
    Mar 2011
    Essex
    Hi
    Well after my "epic fail" of trying to spray my dashboard "piano black" i was introduced to the idea of "carbon fibre vinyl" by westville (thank you kind sir)
    so heres my how too change the look of your dashboard
    tools i used was a craft knife (stanley blade) a credit card to smooth out air bubbles and a hairdryer to stretch the vinyl round tricky curves
    right, heres my poor attempt of a spray which i need to cover
    heres the carbon fibre vinyl i ordered from ebay
    i cut just anuff to cover the lot
    after peeling of the back and sticking over the dashboard i cut some slits in the two main holes
    i rounded and smoothed out the outer edges first using the hairdryer
    then i rounded and smoothed the inner hole (its a bit tricky but with a few well placed slits and the hairdryer to soften the vinyl, it will be ok)
    heres what the reverse side looks like half way through
    a few swear words later and some trimming on the reverse side
    here it is with the air vents scewed back on
    BRFORE YOU CONTINUE PLEASE DICONECT YOUR BATTERY AND LEAVE OR 30 MINS TO BE ON THE SAFE SIDE
    AS YOU DO NOT WANT THE AIRBAG TO GO OFF IN YOUR FACE WITH TINKERING ABOUT !!!
    right, on to the real "EPIC FAIL" lol i really screwed the spay job on this, as i never tried to remove the airbag cover when i sprayed it lol
    this time i removed the airbag cover to apply the vinyl but still left it attached to the straps
    this went on quite easy
    and then i added the other bit
    heres a contrast lol
    JOB DONE !!! and im sooooooo pleased i have finally covered up my spray job lol
    http://i201.photobucket.com/albums/a...P1000905-1.jpghttp://i201.photobucket.com/albums/a...IMG_2078-1.jpg
    Jaguar x-type 2.0d silver 2004 (53 plate)
    WE ARE ALL PRISONERS OF TECHNOLOGY !!!
    Senior Member ElectronShepherd's Avatar
    Feb 2010
    Re: HOW TO CHANGE YOUR DASHBOARD LOOK (WITH PHOTOS)
    Looks really good! Have you considered doing the centre console to match?
    Senior Member astromorg's Avatar
    Apr 2011
    Portsmouth/Southampton
    The photos were quite forgiving of your paint job!! But the new look is really good; very pro. How about the door inserts? Were they wood/piano black and if so is there a plan for them? Also, I note you masked the airbag light for painting. What now? Does the light shine through the new covering or are you going to have to cut a hole in it?
    2005 XK8 4.2-S Coupe and 2006 Auto Sovereign 3.0 X Type Saloon
    westville
    Guest
    Nice one prisoners - now you have to finish the renaiining trim for that super cool look
    Senior Member Tony73's Avatar
    Jun 2011
    Essex
    Nice job mate! Can see why you wanted to cover up that paint job
    I would do the centre console too, although that could be a real tricky task. Certainly would do the ashtray lid to match it up!
    Mar 2011
    Essex
    Quote Originally Posted by westville
    Cheers Jim
    my door trims are black anyway which is nice
    Mar 2011
    Essex
    Quote Originally Posted by Tony73
    you read my mind Tony <----- (great name)
    heres how to do it .......... sorry about the photo quality (used my iphone camera)
    i unclipped the front plastic cover
    measured out a peace of carbon fibre
    and before i could blink it was done
    Then i started on the stereo surround
    i done this bit by bit to save vinyl
    and again, in no time it was done
    as i said before, i didnt need to do the door trim as they were originally black
    Senior Member Fekker's Avatar
    Nov 2009
    Coatbridge
    Good job well done. I was toying with the idea of doing that myself and seeing how easy you did it has made my mind up. I'm puting a car PC into mine shortly so may as well do it all at once. I saw this on another site on an X-Type and the guy also covered up the heater control panel and the hazard switch trim which makes it even more striking.
    2006 Liquid Silver X-Type 2.0D Sport Saloon, factory fitted XS body kit, facelift grille, Parrot Asteroid Smart.
    Jun 2010
    That looks excellent, you should be able to do the top section of the console too, it's just a push fit, the heater facia may be a little more complex tho.
    How did you remove your main drivers side dash .. mine creaks and i's like to pack it out or something. ...
    Jun 2011
    Essex
    Quote Originally Posted by prisoners
    Real nice mate!
    Really looking the complete set now. The thing l'd do next is the plastic gear surround Should be a pretty straight forward job that one.
    I'm definitely having a go at this soon!
