Results 1 to 10 of 12
Thread: New Nav DVD
    May 2006
    Derbyshire
    New Nav DVD
    Hi,
    Long time no post......
    Just been advised my new Nav disk (2011 - 2012) has just arrived on my doormat from Navteq
    Is it just a case now of taking the old disk out of the machine, and putting in this new one. Will it upgrade stuff automatically, or do I have to do this 1971 thing? Ignition on or off?
    1st time I've done this, so thoughts greatly appreciated.... 05 3ltr X Estate, btw (original, as supplied, disk still in machine)
    Jan 2011
    Sydney, Australia
    Re: New Nav DVD
    Hi Mark,
    Congrats on the new nav disc!
    I don't know if there is a new software for the nav system, or if it's just new maps. It also depends on the existing map disc that you have. I'll assume you have an old one (with green logo).
    You need to have the ignition on (car can be running, or not, doesn't matter) so that the navscreen is operational.
    Go to the boot & eject the current disc, then load in the new disc. Any software updates will start automatically.
    DO NOT switch off the ignition until the updates complete. You'll see flashing 51 & 50 (or is it 52?) on the outside temp display while the nav screen is black. Whatever you do don't panic, and don't switch off the ignition!
    The update can take up to 10 minutes or more. Once it's done the nav screen should come back on & you'll have lost all your stored addresses and previous destinations. You'll also have to re-set your home address, search by country etc.
    Good luck & let us know if you see any major improvements with the new disc! Try to take some pics if there are big changes.
    2005 XJR - 12.9 @ 107.6mph
    www.facebook.com/oldjaguarau
    Senior Member BuckMR2's Avatar
    Mar 2006
    Re: New Nav DVD
    If you want the install instructions PM me your email and I'll forward them to you but they are as above
    BuckMR2
    http://i71.photobucket.com/albums/i1...MR2/sigggy.jpg
    Rear Entertainment , 2012 Nav
    DPF removed, EGRs deleted,
    kitchen sink...
    Member Derekosb's Avatar
    Jun 2011
    Glasgow
    Re: New Nav DVD
    Hi there,
    My X-Type has a 2005/06 disc in the system (I only got the car just under 4 weeks ago) and I would be keen to hear your experience with this update.
    can I also ask where you finally sourced your disc, part number and cost? (if you don't mind).
    Derek
    Lexus is220d
    (I know it's not a Jaguar but I still like them and want one again...)
    May 2006
    Derbyshire
    Re: New Nav DVD
    Cambo351,
    Instructions pretty much spot on my friend
    Derekosb,
    Relatively straight forward, Cambo351 has nailed it:
    - With the ignition on, took out the old disk, and inserted the new one.
    - Then got a series of status messages on the screen such as 'Preparing to load system software', followed by 'System software is updating. Version 09.03. Do not turn off the ignition'. All the while the outside temp guage swiches between 51 / 52.
    - After approx 2 minutes, the screen cleared, and displayed the Jaguar Logo (now white on black rather than white on green). The external temp guage also stops switching between 51 / 52.
    - Screen then returned to the Nav screen (if memory serves).
    The update appears to reset the heating settings, and clears all previous destinations, stored locations and the 'home' location. Suspect, although haven't checked it probably also clears the phone address book.
    There appears to be slight cosmetic updates e.g. the compass pointer has changed from the 2 back to back triangles (1 red / 1 clear) to a different graphic. Warning screen also has different wording.
    The biggest change seems to be the way the map is rendered. On the previous version, the pointer stayed in middle of the screen and the map 'swung' around it (with the compass pointer swinging as well). Now the pointer moves, but the map only scrolls up / down and left / right. Haven't yet seen a menu item to change it. Not sure I like it this way.
    The disks are now on line from Navteq (http://www.navigation.com) and cost £169 inc of VAT (also includes free shipping until the end of August). I ordered the disk Weds late morning and received it Thursday am.
    Hope this Helps
    westville
    Guest
    Re: New Nav DVD
    Well done Mark - nice explanation - are you going to add a link on the How To Guides? as this comes up fairly frequently
    Senior Member ElectronShepherd's Avatar
    Feb 2010
    Re: New Nav DVD
    Quote Originally Posted by MarkieMark
    Top left of the screen is a small icon. Press that to toggle between "north up" and "direction up". If you zoom out beyond 2 miles, it's always "north up"
    May 2006
    Derbyshire
    Re: New Nav DVD
    Quote Originally Posted by ElectronShepherd
    Top Man yup - just tried it - pressing the compass icon in the top left of the screen - switches over - and shows the '2 triangle compass icon' that I am used to - pressing againg switches back, brilliant
    Mark
    May 2006
    Derbyshire
    Re: New Nav DVD
    Quote Originally Posted by westville
    Can do ...... err how do I do that?
    Mark
    westville
    Guest
    Re: New Nav DVD
    Done HERE
