Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Air con not cold.
  1. #11
    May 2011
    Re: Air con not cold.
    Dunno - but that was 2 years ago and I laid the car up last winter for about 4 months so the air-con needs a re-gas.(It's not cold!) I'll make him aware of those pipes - thanks for the tip!
  2. #12
    Jan 2011
    Market Bosworth Marina. CV13.
    Hi again Guys,
    Just been under the bonnet with a torch and when the aircon is switched on the compressor (bottom right of engine at front) clutch is not engaging etc.
    Fuses are ok, any ideas guys ?, thanks.
    Supertrev.
    Truly immaculate 2004 XJ 350 - V8 in Jaguar Racing Green which sparkles in the strong sunshine.
  3. #13
    Feb 2012
    Doncaster. South Yorkshire.
    If there is no gas in the system, the compressor does not cut in. Have you checked the gas level yet?
  4. #14
    Jan 2011
    Hi Jagfix and thanks.
    Looks like I'll have to go to my local indie then and pay more money out.
    Slight problem is that he closes at 4pm (can you believe that ?) and I cant get there till 4.15.
    His workshop and office is an absolute rubbish tip which maybe wouldn't inspire confidence with a new customer making enquiries for example.
    Supertrev.
  5. #15
    Nov 2008
    Hampshire
    Why not find a mobile air con specialist, they will be more clued up than just keep trying to gas the system and wonder why its leaking, they can do a full check of the system and let you know what parts have gone, some even carry common parts such as compressor, o rings etc.
    Current Car:
    Previous Cars:
    2000 S-Type 3.0L SE Auto
    2007 XK x150 4.2L Coupe
    Resident Super Moderator.
  6. #16
    Aug 2018
    UK Faversham Kent
    My problem is that with a re gassed system and working compressor, a new pressure valve, a new heater valve and a replaced air con module, the air compressor clutch relay doesn't pull in. Also the PWM cooling fan doesn't operate immediately - it seems to wait until the engine temp rises to normal. So no cold air on hot days even though everything else works fine. Can a faulty thermistorc stop the clutch relay from pulling in? My S type is a 54 3Lt model and is a BRG beauty. The next test I'm thinking of is to short the relay out so the clutch pulls in, and using a table fan in front of the radiator to see if I can get some cold air at least momentarily without risking over pressurizing the system. Any thought anyone? Sorting the air con on my Rover 75 was easy by comparison with this!
  7. #17
    Jun 2012
    Hayling Island
    To be fair, even with a new condensor rad, drier and a full charge, my X type can still blow the S type into the weeds when cooling... Although it might be because the interior of the S is more capacious.
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
  8. Likes orsom weels liked this post
  9. #18
    Jul 2009
    Yorkshire
    Might even be sensor reporting a false temperature (or icing) so it decides not to cool any more.
  10. #19
    Nov 2014
    Norfolk, UK
    Yes, same here, one of the few things that is better on the X type. I wonder if some of the difference is down to the cooling fan behaviour? On the X type, when air con is on the rad fan runs more or less flat out, it's quite obvious that it is working regardless of engine temp, whereas on the S types (all 3 I've had/got) you can hardly detect the fan running unless engine temp is high, & even then it doesn't seem as powerful as that on the X type (2.2D). The X type will deliver ice cold air standing still with the engine at idle, the S types however, only really deliver that amount of cooling when travelling at speeds of over 25-30mph, suggesting to me they need more airflow through the condenser &/or the compressor needs to run faster. When stationary, they do cool below ambient temps, but certainly not 'ice cold'.
    All that said, if the OP's compressor clutch is not pulling in, it won't cool no matter what speed/RPM's the car/fan is doing. My first thought would have been pressure sensor, but it sounds like that may have been replaced, is this what you are referring to by "a new pressure valve"? so second thought, given what has already been done, would probably be a wiring fault to the compressor clutch. The wiring does tend to get quite brittle in that area & can break or become high resistance. If shorting the relay brings the clutch in, that will prove the wiring is OK, if not, kit may be something worth looking into a bit deeper.
    Regards, OW
    1999 S Type 3.0L SE, A truly lovely old girl that's served me well. Probably the best car I've had. Now retired.
    02.5MY (X202) S Type 2.5L SE, 58,000 miles, full Jag s/h, all papers, MOT's, receipts etc from new when purchased.
    2006 X type SE 2.2 Diesel. Supposed to be Mrs O's economical commuter car.
    2004 (X202) 2.5L Sport plus, to replace the 3.0L
  11. #20
    Jul 2009
    Yorkshire
    Mine does not behave as just described. Fans run fast, air is ice cold.
    Difference due to it being X202 / STR?
