Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Jaguar X Type Guide to: How to Check for Sill Corrosion
    Senior Member astromorg's Avatar
    Apr 2011
    Portsmouth/Southampton
    Prompted by other recent posts about rusting metalwork out of sight behind the plastic sill covers, I recently removed mine to give me peace of mind! For those who might want to do the same but feel it might take too long or are unsure if it's within their capability, here's an account of what I did with some photos to help. Each side can be removed and replaced within the hour and if you're reasonably agile, there's not even any need to jack the car up! Note this account covers a MY2005 X Type and it would be useful if anyone knowing of any differences in earlier or later MYs could post the information.
    The sills are held in place with two rows of plastic clips. The first row is visible from under the car and comprises nine clips, such as shown here:
    If you're lucky, about half of these clips will come out as intended, using a small Pozidrive screwdriver to remove the centre screw. It requires the minimum pressure on the screwdriver to have any hope of success! The centre screw should come out and the outer part will then just pull out by hand. If it doesn't unscrew, then you'll need to lever the screw out with a very fine screwdriver, as shown here. Note the rust in the seam before I've even got the cover off - but not much to worry about yet!
    When all nine are out, the sill can be removed by starting at one end and pulling it straight out - not up and down. It will resist as it's still being held by another row of hidden clips, but once the first one is out, the rest will follow very easily. This photo shows the white clips you're trying to remove and also one of the two black locating pegs that help locate the cover when replacing it.
    Having removed the cover, what's underneath? Hopefully, something like this; a dusty, but rust free structure so you can clip the cover straight back on and relax for another few years. If not, well maybe you've discovered it before it's terminal!
    Having carried out whatever remedial work may be required, all that's left now is to refit the cover. Having located the guide pegs in their holes, a series of firm hits with the palm of the hand on the cover will relocate the clips. Then replace the nine clips under the sill and the job is done. I just hope that whatever you found let's you sleep more easily at night.
    See http://www.jaguarforum.com/showthrea...sill+corrosion for details of an internal examination of the sills
    2005 XK8 4.2-S Coupe and 2006 Auto Sovereign 3.0 X Type Saloon
  2. Thanks Jim Stafford, Administrator thanked for this post
    Senior Member smokie612's Avatar
    Nov 2011
    Grt Manchester.
    Hi Astromorg, I read the posts last week and thought about checking my sills, now after reading your guide I will do them when the weather improves,
    Thanks Ken.
    Cheers Ken.
    2011 61 JAGUAR XF 2.2 D LUXURY 4D 190 BHP DIESEL FACELIFT MODEL
    Crystal Blue Met
    Previous..
    2004 X-type 2.0D Radiance Red ...3Yrs
    2002 X-type 2.1 V6 Agean Blue....3Yrs
    Granada's 2.8 Ghia / GL's Too many to mention
    Granada 3.0 Ghia
    Senior Member stue's Avatar
    Dec 2006
    sunderland
    Would it not be a good idea once removed to give them a good clean and waxoil since the won't be seen again?
    http://i71.photobucket.com/albums/i1...2/stu/65xx.jpg 2004 2.7 DSE
    Bi-Xenons, Sat Nav, Fixed Phone, F and R Park Aid, Headlamp Wash, Heated Seats, Jag Voice, Elec Rear Sunblind, Auto Lights and Washers, Auto Dimming mirrors, Heated front Screen, Memory Seats, CD Multichanger.
    Senior Member Chrisspencer's Avatar
    Feb 2010
    Newcastle
    Quote Originally Posted by stue View Post
    Waxoil or even a good stone chip type of undersealant?
  6. #5
    Senior Member Big cat little cat's Avatar
    Jan 2011
    North Midlands.
    Very informative as usual Astromorg. I've just been outside to lie on the floor and look at mine. They look very similar to yours, even the same colour!
    I too have the rusting in the seam, but it's like any other car that age, not too deep and as you say, not to worry about yet. The lower face of the sill looks slightly grubbier than yours, but it never gets washed! I have the OEM mudguards fitted, so I think this will have kept some of the grime away.
    Maybe I'll get the sill covers off next week, weather depending.
    Just when you think you can see a light at the end of the tunnel,
    you find that it's just someone with a torch bringing you some more work!
    XF 4.2 Premium Luxury. (present)
    XF 5.0 Portfolio. (2017-2019)
    X-type 3.0 Sport Premium Estate Auto. (2011- 2018 )
    Opel Monza 3.0 GSE. (present)
    Link to retro fit cruise control for 2004-on AWD cars here. http://www.jaguarforum.co.uk/f26/ret...+control+retro
  7. #6
    Jan 2011
    Sydney, Australia
    Good post Astromorg!
    Mines got the rust in the seam too, but i don't think i'll be pulling off the sill covers any time soon.
    Having seen a number of posts online showing horrible pictures of rusted out sills, i'd rather not know, ignorance is bliss!
    2005 XJR - 12.9 @ 107.6mph
    www.facebook.com/oldjaguarau
  8. Likes Royston 19 liked this post
  9. #7
    Jan 2011
    North Midlands.
    I'm going to have a look at mine because I'm a nosey f***er.
    The pics of rusty sills that you've seen Cam, would you see the rust before taking the cover off or is it hidden at the side of the real sill, under the plastic cover?
  10. #8
    May 2010
    I'm with Cam, ignorance is bliss.
    I once checked my old Discovery and discovered (no pun) there weren't any sills, just plastic covers and irony red water.
    At the same time I went looking for the boot floor and rear wheel arches, I think they must have divorced the car some point in the past, packed and left!
    All that stopped my ready meals falling out was the boot mat!
  11. #9
    Jan 2011
    Sydney, Australia
    All from 03 X-Type Rust - Jaguar Forums - Jaguar Enthusiasts Forum
    Seems the problem was with the early cars, if you parked them on a sloping driveway (nose downwards) water would pool up in the sills.
    Later models had strategically placed drain holes at the front...apparently...something about the 2004.25 facelift...
    Even with the plastic sill covers removed you can't see all this. The sills are double-skinned.
    Apart from pics 3 & 4 above, all those shots are with the outer metal skin of the sill cut away.
    Pic 3 & 4 are with rust so bad, it made it's way to the outer skin as well....
    As I said, did you really want to know??? What has been seen cannot be unseen....
  12. #10
    Jan 2011
    North Midlands.
    The photos are not showing to me, so there are still unseen!
    I'm hoping that my car will be ok due to it's age and general condition. I'll report back once I've looked.
  13. Thanks SpaldingSparks thanked for this post
    Likes SpaldingSparks liked this post
