Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
Thread: choice of aftermarket double din stereo
    Jul 2013
    Gateshead
    Hi there
    Just decided to upgrade audio on my 04 estate, and would like to use double din unit. Don't want to watch DVDs in my car but i want Bluetooth conectivity. At the moment i got Parrot MKI9200 and its nice thing, but i want even better quality. (btw if anyone would like to buy Parrot MKi9200 with x-type harness please PM or bartnik.bartnik@gmail.com ) Anyway here is what i found.
    CLARION CX609E Click image for larger version.
    JVC KW-SD70BTClick image for larger version.
    Kenwood DPX-405BT Click image for larger version.
    Or Sony WX-GT90BT Click image for larger version.
    All of them got Bluetooth , about 4 x 50W RMS ,variable key illumination and USB / line in ports
    Price is similar - about £130 - £150
    Here is questions:
    Does anyone got them fitted in x-type before (I know about depth problem )?
    Which one would look best on x-type dash ?
    Thanks in advance
    Senior Member jagryan85's Avatar
    Feb 2012
    Wirral|England|UK
    JVC or Sony. Only ones that'll last.
    Check the measurments for the depth, they can be a problem!
    Ryan
    "One shall not fix something if something need not to be fixed"
    2005 4.2 V8 S-Type Executive - Sat Nav with Reverse Camera, DVD, Winter Pack - Auto HID's & Wipers, Headlamp Washers & Heated Seats. F&R Parking Aid, Power Folding Mirrors, Mesh Grille, Memory Seats, 18" Mercury's, Towbar, Privacy Shades, Parrot MKi9200, Dash Cam.
    Previous: 01 X-Type 2.1 SE, 01 X-Type 2.5 SE, 02 X-Type 3.0 Sport
    Summer Toy - 2007 Triumph Sprint ST 1050 in Caspian Blue
    Senior Member Nyces's Avatar
    Mar 2012
    Peterborough
    I have a sony xav, I had to modify the fascia with fibreglass so the head unit sat on the front and not in the grooved seat as the depth.
    There's some picks on the forum somewhere and few others have had success in sorting it
    2001 3.0 X Type SE Emerald Green, Full Tan Leather. Check my build thread here >> http://www.jaguarforum.co.uk/f69/nyc...ype-44906.html <<
    Jul 2013
    Gateshead
    Quote Originally Posted by Nyces View Post
    Thanks for info - will read more.
    Just checked and XAV depth is 7 inch (17,8cm)
    Kenwood DPX-405BT which I decided to buy, is only 15.7 cm so fingers crossed
    BTW. Parrot is reserved for jagryan85 so please stop asking about it
    Senior Member XMan2002's Avatar
    Feb 2013
    Flower Mound, Texas USA
    All good choices but I believe none are 50W RMS - that's peak power. Most are rated between 20W - 22W RMS - sufficient enough power for the X-Type with its arch-curved interior cabin.
    2002 X-Type 2.5 V6
    Mina Inserts HID+LED+DRL Chrome Mirror Caps/Petrol Flap/Sleeves Clear Markers/Repeaters REMIN/RVINYL Carbon-Fiber Trim Facelift Plinth NGK Red Tail Tips H&R SS Sports Edition F10 17x8 Hankook 225x45ZR17 Ventus V12 Silver Calipers w/Decal Drilled/Slotted Rotors EBC/Red Stuff K&N 2-Tone GL Steering Wheel Cover Sheepskin Inserts Alum/Dead Pedals HR Leaper SP Lights Infotainment: iSimple TranzIt BLU HF Sony XDP-MU110 DSP 8-Speaker+JBL BassPro SL WiFi Dash-Cam Laser Radar Detector
    Jul 2013
    Gateshead
    Quote Originally Posted by XMan2002 View Post
    You are 100% right :" built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)" . My mistake
    It still must be 100% more than factory - non amp stereo have.
    Anyway - I think that if I use small active sub (got VIBE CBR12 of my previous car) + all new 2 way speakers in doors (Hertz 17) , results should be quite good ( not a techno/dance/hiphop fan)
    Feb 2013
    @BARTNIK
    Yes the stock non-amplified system is rated between 8W - 11W RMS (25W - 35W Peak) depending on the year. I too have a non-amplified aftermarket solution that's rated at 17W x 4 RMS (50W Peak) and I just love sitting in the car while parked under the port listening to my music.
    Infotainment Upgrades: SONY XDP-MU110 DSP, iSimple TranzIt IS77, Arkon SM432-G Mobile Mount, Massive Audio SX6+VX6 Coaxial, Pioneer TS-T110+SONY XSH20S Tweeters
    2002 X-Type 2.5 V6
    Mar 2012
    Peterborough
    Heres my Sony XAV;
    I had to fibre glass mod the fascia so the unit sat at the front and then vinyl wrapped it for a finish.
    Jul 2013
    Gateshead
    Good job Nyces - I hope mine will just fit flat (I know that its way too optimistic )
    Meanwhile new radio arrived - now just waiting for fascia, autoleads stalk control interface and antenna converter. Will post some pictures and I'll try to take measurements of available space in dash
    Jul 2013
    Gateshead
    Ok it fits
    So for future generations - max depth of double din is 15,7 - 16 cm (don't really care about inches )
ID:	5650Click image for larger version.
    Improvement in sound is massive. Now all I need to do is upgrade speakers.
    BTW stalk conector adapter from Autoleads does not work - will send it back and get Connect2 (10 pounds cheaper)
  11. Likes Daz69, jagryan85, dutch-black-X, graham-r liked this post
Tags for this Thread
