Results 1 to 10 of 13
Thread: Estate tailgate glass hatch reprogramming
    Senior Member BenedictWhite's Avatar
    Oct 2013
    Mid Sussex
    Just trying to reprogram my glass tailgate hatch
    Start JLR SDD
    Get Vin
    Go to service functions (This gathers data for a tediously long time, ask some questions then does it again for a tediously long time)
    Select "Recomendations" (It will ask if you have a DPF fitted)
    Select Dealer options at the bottom.
    Set ignition to on and press the tick on the right.
    Scroll down to "Tailgate release by remote" and set it to "Sports brake tailgate glass enable" then press button at the top right then press the tick.
    Or something like that...
    The program will ask you to turn the ignition on and off several times and if you have the engine running will during a reprogram turn the engine off. You may have to remove the key to get it to turn back on.
    Edit:
    Now pressing the boot/tailgate button on on the keyfob opens the glass, but also unlocks the tailgate so you can open that in the normal way
    Last edited by BenedictWhite; 29-11-13 at 19:39. Reason: Add information on what the reprogramming does
    Kind regards
    Benedict White
    Jaguar X Type Sport Estate 2.0D, 2004 (127,000 miles) with most of the toys!
    To edit your signature, go to the top right of the forum and click on settings. On the left side you will see 3 panels, The 3rd is "My Settings". Under my settings you will see edit signature.
    How to re program tailgate glass see here.
    May 2013
    Nice work Benedict! Sounds handy to me, I use the hatch quite a bit.
    Senior Member motco's Avatar
    Feb 2012
    Chilterns
    But then if you use the hatch and close it you have to lift and drop the tailgate to relock it, surely? I'd rather use the manual switch to release the glass, and the remote to release the tailgate. Incidentally, it may be only my car, but the tailgate gas struts are feeble and won't guarantee to raise the gate fully without a hefty shove in cold weather, and don't help sufficiently with tailgate weight when opening.
    Senior Member Andy5112405's Avatar
    Redditch
    I've got the same problem with the gas assist. New gas struts made bugger all difference.
    I've got some uprated ones but haven't got around to fitting them yet.
    2067 plate XF 3.0TD-V6 Sport Sportbrake, another ex-demonstrator with all the toys.
    2013 XF Sportbrake 3.0TD-V6 Premium Luxury. All the toys that were available.
    Previous Jag's. 2001 2.5V6 X type SE Saloon & 2008 2.2TDi X type Sovereign Estate.
    Oct 2013
    Mid Sussex
    Quote Originally Posted by motco View Post
    No, the keyfob just opens the glass not the tailgate so you don't need to lift that to close it. It does however unlock the tailgate so that you can open it on the switch and as you have to put your hand there to lift it I can't see that as being much different.
    My rational for doing the job is simple, the switch on the tailgate glass for opening the glass didn't work so I've just bypassed it in software.
    Kind regards
    Benedict White
  6. Thanks JEK thanked for this post
  7. #6
    Feb 2012
    Chilterns
    Okeydokey, Fairy Nuff!
  8. #7
    Skyedriver
    Guest
    Quote Originally Posted by BenedictWhite View Post
    Start JLR SDD
    Get Vin
    Edit:
    You lost me after the word "Start"..................
  9. #8
    Oct 2013
    Mid Sussex
    Ah... well it does involve using the cheap mongoose (search "cheap mongoose" as a thread title).
    Kind regards
    Benedict White
  10. #9
    Jun 2012
    Hayling Island
    Going to try this today. Mine has started the infamous "Unlock hatch when starting" problem.
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
  11. #10
    Jun 2012
    Hayling Island
    And much as I tried to get this to work... It wouldn't. Must be missing something.
  12. Thanks JEK thanked for this post
