Results 1 to 9 of 9
Thread: How do you turn off Autolock without a dealer?
    Junior Member Jonathan Rowley's Avatar
    Dec 2013
    Cheshire
    I nearly got locked out of the car this morning, son put keys in and the doors locked, luckily the boot was open as we were still loading with Xmas goodies!
    Is there a way to de-activate this feature?
    Jaguar S Type 3.0 V6 - Year 2000
    Land Rover Lightweight
    Dnepr MT10-36 - Bike and Sidecar!
    You could try an indy who has dealer level diagnostics, but either way I'm pretty sure it can only be switched off via that level.
    Sorry it's not much help,
    Telford UK
    Yes its a tick box on ids. You'll need a dealer/Indy with jag diags system.
    May 2007
    Hungary
    I am not sure what really happened but it had nothing to do with the autolock feature. Autolock activates when the speed reaches 3 mph.
    2001 3.0 SE
    Jul 2009
    Yorkshire
    Probably pressed the door lock lever or button. Agree - nothing to do with auto-lock.
    Cylon
    Guest
    Quote Originally Posted by Jonathan Rowley View Post
    There is. Don't let the kids have the keys.
    Senior Member Steve S Type Sport's Avatar
    Dec 2013
    Northumberland
    Turn on the ignition so all the dash lights come on but don't start the engine.
    Lock the door using the button on the door handle and then unlock the door (but don't open it) 3 times.
    Turn off the ignition.
    Turn on the ignition but dont start the engine - you should be able to hear a beep.
    Lock the door again as before then unlock it (only once this time) - a final beep should be heard.
    If all goes according to plan your doors should now not lock when you go over a certain speed (about 5-10mph). This will also auto lock the doors if you reverse away. This mod will be operational until you repeat the above steps to switch it on. It will only work once for each time the car is started though. In other words, if you unlock the doors to let someone out without turning the engine off, they will not automatically lock when you move away again.
    2.5 V6 S-Type Sport
    JOUEC Jaguar Owners Unite Enthusiasts Club.
    Google is our friend!
    Senior Member JohnW's Avatar
    Dec 2013
    Belton, NW Leics
    A great answer from S Type there.
    In 7 years I've never had a prob with autolock. Our MG is a pain as it auto-locks @ 20 mph but doesn't un-auto lock when you pull the door pull like the Jag does.
    I'd agree that the prob was a child-related finger interface issue. Someone locked the doors when you weren't looking.
    Dec 2013
    Cheshire
    Thanks for the answers, must have been finger trouble but who knows.
