Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: s type 2001 3litre, offside drivers window problem
  1. #11
    Jun 2013
    My advice: First remove yours to see what is the exact problem!
    If you need one you can get the whole mechanism from ECP, still 30% off today using the same code.
    If you can't get it in time you can raise the glass and wedge it closed temporarily.
    There are videos on YouTube on how to get the door trim off, it's dead easy but note where the screws are first.
  2. Thanks picalopete thanked for this post
  3. #12
    Apr 2012
    S type pax door window
    Thanks for your message but will you give me details of who and where are ECP ?
    what is the price that you are relating 30% discount to?
  4. #13
    Jun 2013
    Quote Originally Posted by picalopete View Post
    Euro Car Parts also have them, £154 for mine.
    Today you get 30% discount with code SALE30 if you buy online at www.eurocarparts.com
    Here you go, it's all in this thread already.
    Euro Car Parts are suppliers of... Car parts... in the UK.
    There are others too, like Motor Parts Direct, and Unipart, and they are known as "Motor Factors".
    I don't know exactly why. In Maths we know factors as components of a number or formula. So there may be the answer.
    Click on the link I gave you and put in your registration (if your car has a UK registration number) or select your car manually from the options, then look in "Shop All Departments" for "Body and Exhaust", then "Window Regulators and Winders".
    They have the left and right front mechanisms but not the back ones.
    The discount code is still active.
    Are you not in the UK, since you don't know of them? Where are you located?
  5. Thanks picalopete thanked for this post
  6. #14
    Apr 2012
    I am in the UK , Surrey.
  7. #15
    Jun 2013
    Great, so there should be an ECP not far from you, but they deliver anywhere too.
    See if you need one first.
  8. #16
    Nov 2012
    Carlisle
    or check ebay
    http://www.ebay.co.uk/itm/Right-Hand...8AAOSwX~dWsI5s
    the seller is actually david manners so more reputable than ECP for JAG bits.
    TT
    Current Cars
    2002 Galaxy 2.3 Ghia - State Blue
    2000 Focus 1.8 Zetec Breaker Panther black.
    1987 Sierra Sapphire 2.3 8v Project - Galaxy Blue
    2007 Transit 350-100
    Past Jaguars
  9. #17
    Senior Member the fussy one's Avatar
    May 2012
    Bedford
    If its your daily driver just change the whole unit. The David Manners one on TT`s link looks about the right money.Otherwise you may have the door stripped down for however long it takes to get parts.Doubt anyone will sell twopenny parts so just put a new unit in and job done.
  10. #18
    Nov 2012
    Carlisle
    if the motor is ok, repair kit for slides and cable is ~£10-£12. Couple of hours work.
    TT
    Current Cars
    Past Jaguars
  11. Likes churchy liked this post
  12. #19
    Apr 2012
    Hi, I have now started on my Jag window repair, feeling along the bottom inside the door I have found a small piece of plastic and found it belongs to the forward slider, but there is a cable attached with a spring and I am not sure how to detach this cable from its plastic slider housing, the plastic slider where the cable enters is sealed, so can anybody tell me what to do next?
  13. #20
    Nov 2012
    Carlisle
    You need to get the Mech out. it's 5 10mm nuts from memory plus the two bolts that clam the glass. There are two inspection holes for the glass clamps which you have to lower the window to get lined up if you can't lower the window then you will have to fiddle with a spanner to get to the bolts.
    TT
    Current Cars
    Past Jaguars
