Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: s type 2001 3litre, offside drivers window problem
  1. #41
    Apr 2012
    I have read all of that info thanks, but I don't think it's applicable to a UK spec 2001 s type, only thing I need to do is reset the radio code. Fiddling with the up/down switches made no difference.
  2. #42
    Nov 2012
    Carlisle
    Did you clamp the glass when it was almost at the top of travel?
    Current Cars
    2002 Galaxy 2.3 Ghia - State Blue
    2002 Galaxy 1.9TDi 130 Zetec - Blue
    2004 Renualt Megan RS 225
    1994 Escort 1.6Efi Solar Cabriolet
    1987 Sierra Sapphire 2.3 8v Project - Galaxy Blue
    2007 Transit 350-100
    Past Jaguars
  3. #43
    Jun 2013
    Quote Originally Posted by picalopete View Post
    That's news to me.
    The window will only go up in short steps to avoid strangling someone because it doesn't know where the frame is until you take it to fully closed then hold the "up" switch for a few seconds so it will know and remember the fully closed position.
    Then take it down to fully open and hold "down" for a few seconds to set that position too. Repeat for the other windows.
    If it still only steps up after you do this, then the new regulator is not 100% compatible or the window is jamming in the channel.
  4. #44
    Nov 2012
    Carlisle
    It's not location it's learning, but the current drain when the motor stalls. ( if it knew where the frame was it could still happily chop off a finger or strangle someone)
    It should only matter for one touch, if the motor stalls even with the button pressed during part travel then something is wrong.
    TT
    Current Cars
    Past Jaguars
  5. #45
    Apr 2012
    I spent 2 days just on this regulator, removed it 3 times to ensure nothing was being trapped and greasing with the silicon grease, clamped it in the up position, tried it many times with the engine running to boost the battery voltage, tried the resetting using the up and down switches, got fed up in the end and just decided that the replacement motor is not suitable for the job. As I also said previously the original motor is not interchangeable. After all it is only the pax window and I have decided to live with that.
  6. #46
    Jun 2012
    Hayling Island
    My next job...
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
  7. #47
    Nov 2012
    Carlisle
    X2 ... One rear went last summer, one in november...
    I have the parts car to strip them off...
    Current Cars
    Past Jaguars
  8. #48
    Senior Member Marcuspd's Avatar
    Aug 2018
    UK/ Ashford, Kent
    Quote Originally Posted by twin--turbo View Post
    The regulator repair kits are so cheap (£15 a pair for mine), is it worth putting equally old brittle plastic clips in?
    Jaguar S Type 3.0 V6 Sport 2001.
  9. #49
    Jun 2012
    Hayling Island
    I thought that too. That's why I went for the kit instead.
