Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
Thread: s type 2001 3litre, offside drivers window problem
    Nov 2014
    hi members,i need to know how to remove drivers door card and what tools are required,as my window dropped the other day and would not go back up,so managed to get glass to the top and wedge it there temporarily with bits of wood,could this be a broken scissor mechanism,any help or advice welcome.thanks. great site.
  2. Thanks picalopete thanked for this post
    Senior Member paulkebab's Avatar
    Mar 2013
    Great Harwood, Lancashire
    Sounds like a broken scissor, probably repairable.
    This is how I did mine - the 'cup' behind the open/lock lever needs to be gently prised away, then remove the two self-tappers underneath the little mat on the inside of the door handle. After that its just a case of easing the card away from the clips, the best way is to wind the window fully down ( or carefully lower it! ) and start from the top. Some plastic wedges would be handy because if you tug the card the clips will probably break. Almost all the clips are on the edge of the door, just two are nearer the centre.
    Previous : 1992 3.2 XJ40, 1997 4.0 V8 XJR - Current 2003 4.2 Black STR
  4. Thanks picalopete thanked for this post
    Apr 2012
    My 2001 s type 3ltr S has just given me this same problem, can you specialists explain to me what the scissor mechanism is all about, how is it repaired, should I need to replace it are there pattern types you could recommend and where from, or is it a visit to the Jaguar stores?
    Senior Member the fussy one's Avatar
    May 2012
    Bedford
    Plentiful on ebay. Main dealer will want an arm and a leg!! Cable has either snapped or jumped off of a worn spool, quicker to replace the complete assembly.
  7. Thanks picalopete thanked for this post
    Likes picalopete liked this post
  8. #5
    Senior Member Davidsw's Avatar
    Feb 2014
    Cornwall UK
    search ebay for s type window regulator
    Jaguar XKR x150 Cabriolet 2010
  9. Thanks picalopete thanked for this post
  10. #6
    Senior Member Neilr's Avatar
    Jan 2007
    Germany
    Take a look and decide how worn or broken the parts are. One or other plastic slider goes brittle and breaks. I only had to replace one slider (I probably replaced both ...) in one window so far but I now have spares for a front and a back one for when the next one goes. Look up "regulator" and select the pre-facelift years and you will get an idea of all the options from just the sliders and pulley wheels, through cables to the complete assembly.:
    http://www.ebay.co.uk/sch/i.html?_fr...s-type&_sop=15
  11. Thanks picalopete thanked for this post
  12. #7
    Jun 2013
    Euro Car Parts also have them, £154 for mine.
    Today you get 30% discount with code SALE30 if you buy online at www.eurocarparts.com
  13. #8
    Nov 2012
    Carlisle
    It's not a scissor it's a cable mech.
    Not sure about prising away at the top firs either as they sit in a channel at the top IIRC ( will have a look when it's light)
    I repaired one and it was a right X%$£%% , but I think I know the trick now which is to re-lace the cable but not over one of the end spools ( you can't get the bobbins in the drump if its fully laced) then ease the cable over the final spool like using a tyre leaver.
    TT
    Current Cars
    2002 Galaxy 2.3 Ghia - State Blue
    2002 Galaxy 1.9TDi 130 Zetec - Blue
    2004 Renualt Megan RS 225
    1994 Escort 1.6Efi Solar Cabriolet
    1987 Sierra Sapphire 2.3 8v Project - Galaxy Blue
    2007 Transit 350-100
    Past Jaguars
  14. Thanks picalopete thanked for this post
  15. #9
    Apr 2012
    Thanks for this link, now I have a good idea about tackling this job. Any more thoughts to assist would be greatly appreciated.
  16. #10
    Nov 2012
    Carlisle
    Removal and refitting is simple. The trim round the door release handle can be a real pain, no real trick to it either.
    TT
    Current Cars
    Past Jaguars
  17. Thanks picalopete thanked for this post
