Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: Cruise problem.
  1. #11
    Senior Member Rondu's Avatar
    Nov 2010
    Glasgow
    Battery voltages:
    12.65...100%
    12.45...75%
    12.24...50%
    12.06...25%
    11.89...0%
    Is the Cruise you have normal or Adaptive, as far as I know they changed to Adaptive Cruise as an option on later Cars, just wondering if ASL was included, though there is no mention of it in any of the Brochures or Handbooks, I know other Jaguars with ASL have a switch beside the Gear Shift, in those Cars Cruise won't work if ASL is switched on, just wonder if a previous owner has fitted a Cruise system from the XF, though ASL systems normally have a knurled setting wheel on the Steering Wheel Controls, or perhaps the wrong Module has been fitted at some point.
    Doug.
    My Boat,Train, Plane & Crane
    2002 STR Zircon
    2003 Mazda Mx-5 Montana
  2. Thanks Jim_S-V6_2004 thanked for this post
  3. #12
    Jun 2013
    Rule of thumb - Each cell is at 2.1 volts when fully charged, and there are 6 cells. So 12.6 volts-ish as per Doug's info above. If it's less than 12 volts it's bad, or has been steadily discharging through the winter if you are doing short trips it won't have time to recharge properly.
    People think car charging systems are magic - they aren't, they need help sometimes.
    So if you are doing short trips, stick it on a mains charger overnight, 12 hours if possible, and then see how it goes after that.
    But if you are doing long journeys then still charge it overnight to check it out, but it may well be duff.
    Used to have: Superb Silver 2004 2.5-litre V6 petrol, ZF Auto box
    Don't believe anything I say - Alzheimer's is setting in!
    Links:
    The Coffee Shop Thread: http://www.jaguarforum.com/showthread.php?t=65758
    S Type Stickies: http://www.jaguarforum.com/forumdisplay.php?f=104
  4. #13
    May 2009
    WARNING: Contents may contain total cobblers
    Quote Originally Posted by Andy the tyre man View Post
    being brought up in the yorkshire countryside I've dabbled into various air rifles. Why do you ask?
    I've seen the 'well I'll be....' in your sig on a popular airgun forum and thought it may have been yourself?
    Si.
    07 S-Type 2.7D SE with many toys, if it offered to massage my testicles while driving it wouldn't surprise me !
    This ones got a lightey up ashtray already Andy !!
  5. #14
    Senior Member Mr Lawrence's Avatar
    Jul 2014
    Trefnant, North Wales
    Been using that sig on loads of forums but not any air gun ones.
    Used to to have it on my bike reg plate.
    WHALE OIL BEEF HOOKED
    2006 Jaguar S type 2.7diesel V6 se manual in ultra violet blue with nav, 5in oval powerflow backboxes.
    2nd car, when im allowed to drive it, is a pretty 1998 m.g.f in solar red. (Now packed away for winter)
    3rd car, wifeys baby, is a 2015 Abarth 595 custom in legends blue.
  6. #15
    Senior Member Fusilier's Avatar
    Jun 2012
    Newton Aycliffe
    Had the same problem recently, and when it went in for service, they said no faults found, and did not know what it was, but left if for a couple of weeks, and it fixed itself, and been perfect since, I did not attempt to use the cruise during that period, then on way to work tried it, and it worked perfectly
    Stu
  7. #16
    Jul 2014
    Thanks. I'll try that.
  8. #17
    Senior Member police666's Avatar
    Nov 2011
    liverpool city center
    have you tried a battery reset yet ?
    -----Click the link below to go to my Jaguar files, including-----
    --JTIS, JEPC, TSB's, Technical Guides and Service Manuals--
    . https://www.mediafire.com/folder/luzulsu07dpcc/jaguar
    ---------------IDS SDD software v138 and manuals--------------
    https://www.mediafire.com/folder/8kq...q3/IDS_SDD_JLR
    ---------------------DVD videos to download-----------------------
    https://www.mediafire.com/folder/v9y...1jq/Dvd_videos
  9. #18
    Jul 2014
    Tell me more!
    Digging around i found the negative battery lead was almost cracked all the way through!!
    Phoned jag, £77+vat
    local to to me is a car accessory/tool shop, exact same lead.......... £4.99!! Sold to me!
  10. #19
    Nov 2011
    disconnect your battery and leave it overnight or touch the cars + lead to the - lead when the is NO battery in the car.
    it will reset certain modules.
  11. #20
    Senior Member Cata1yst's Avatar
    Mar 2010
    Neuheim, ZG, Switzerland
    Well I managed to engage cruise at 120mph once in Germany, with a S Type R.
    I think from memory it wont engage above that? I will try soon when I come home for Easter and report back. I think 120's the limit.
    How often someone would get to engage cruise above that is beyond me.
    x3 Jaguars when 2 is not enough ....2002 3.0L X- Type Sport, 2002 4.2L S Type R, 4.0L 1999 XKR
