Page 19 of 19 FirstFirst ... 91516171819
Results 181 to 186 of 186
Thread: ZF' Gearboxes in Jags
  1. #181
    Apr 2011
    They sell without fluid, got this but did not link directly as wasn't sure what box his XJ has
    https://www.ebay.co.uk/itm/JAGUAR-S-...item281f3ea1a5
    http://www.oilexpert.co.uk/
    XF SV8 A - USB 2 - B&W 440W - Parking Aid Pack with Rear Camera - CAT Suspension - TPMS - 20" Volans - Headlamp Powerwash - Rain Sensitive Wipers - Xenon Headlights - Heated Windscreen - Intrusion Sensing - Navigation with DRG and TIS - ACC - Forward Alert - Memory Function - Blind Spot Monitor - Bluetooth Connectivity - Automatic Headlamp Leveling - JaguarVoice
  2. Thanks alan@agilecomputers.co.uk thanked for this post
  3. #182
    Jun 2013
    Right, Santer.
    Alan it's best you call the suppliers to be sure these will fit your gearbox before you order.
    The S gearbox is the ZF 6HP26, yours might be the 6HP19 I don't know?
  4. Thanks alan@agilecomputers.co.uk thanked for this post
  5. #183
    Member alan@agilecomputers.co.uk's Avatar
    Mar 2013
    Bourne End, Bucks
    Thanks Jim and Santer,
    Really helpful info and advice from you guys, as always. The box in my X358 is the same ZF 6HP26, so I'll contact these suppliers for the service parts I need.
    Best regards,
    Alan
    XJ Sovereign 2.7 TDVi, January 2008, Indigo Blue Pearl
  6. #184
    Dec 2015
    Norfolk
    Quote Originally Posted by jberks View Post
    I guess the real test with the Comma, is gearbox wear over time compared to the genuine ZF stuff. It may shift ok for a period, but for the long term? and when it slips, what damage is being done? £60 seems too cheap - though I have no evidence on which to base that, just gut instinct which is hopelessly unreliable.
    Comma is generally on the cheap DIY side of things and as a brand I'd not use it in the engine, though I do use Millers.
    Sorry, i've not been on much, so this is a bit of a delayed answer. Yes I do agree that 60 is a bit on the cheap side and I am still wary of cheap. However, I don't think that the fluid would deteriorate any more than any other hydraulic fluid. If it was wrong for the box then it should have been wrong from the start. The Jag is still running on it and clocking some miles.
    XF 3.0 D Luxury 2010. And no, chemical fixes can be handy, but do not replace technicians.
  7. Thanks jberks thanked for this post
  8. #185
    Dec 2015
    Norfolk
    Quote Originally Posted by alan@agilecomputers.co.uk View Post
    Hi Richard,
    My XJ X358 2.7D is approaching 75k miles and has never had the gearbox fluid changed to my knowledge, so it's a job I want doing in the new year. I'd like to use Ian at Leapers in Thame, Oxon (local Jag indie specialist) because I've found him to be very good. However, he has quoted to drop the sump and double fill to first flush the torque converter and oil cooler and then replace with fresh ATF with a new pan/filter. This uses a lot of oil so works out quite wasteful and pricey, plus I'd rather employ your recommended method with the Launch CAT501 machine to replace 100% of the fluid, the sump pan, filter and mechatronic sleeve/seal. If Ian had one of your machines I'd use him without question, but I'll probably end-up using Autotech BMW in Slough.
    I'd like to supply my own ATF from either Smith & Allan or Westway Lubricants, but can you (or any others on the forum) recommend a good source for the pan and filter kit, together with all the bolts, the mechatronic seal and sleeve? As all the Christmas credit card bills drop on the mat just when I contemplate needing this doing in January, it would be handy if I could save a few bob on this job! Thanks in advance for any advice.
    Regards, Alan
    Hi Alan, sorry for the late reply. I like the Febi fluid available from Euro Car Parts, it seems to be an exact match for ZF fluid, even the colour is exactly the same.
    Did you manage to get it done before Xmas?
  9. #186
    Apr 2016
    Near Berlin
    Hi Bluechem,
    A quick question for one of Swiss forum members.
    Are there any of your gearbox service machine in switzerland
    Grumpy Old Git
    Napoléon Bonaparte
