Results 1 to 8 of 8
Thread: Electric gremlins getting worse Series 2 4.2C
    Jun 2016
    First it was only the horn and the washer motor. But if i count all gremlins they are far worse. The fuel switch doesn't work, The interior switch doesn't work, The door lights switch doesn't work. The car runs very good on LPG but when i switch to petrol it stops running. I suspect no fuel pump. The clock doesn't tick. Rear windows don't open but the front work fine.
    All the fuses are fine. The car has a key less entrance and a starter button. No key. Can it be that the hobby mechanic who did this forgot to connect a few wires or it is a groundig issue? I can i investigate it the best way. I'm have a multi meter but i'm not really handy using it. All help is welcome.
    Member Shug's Avatar
    Feb 2013
    Newcastle upon Tyne
    Hello,
    I'm not an electrician so the specifics of your problem I'll leave to those with better knowledge.
    However, see if you can look at the 2 attachments as it will hopefully show you the wiring diagram for the XJ6C4.2.. I hope it helps.
    http://i1341.photobucket.com/albums/...psyjljxsyj.jpg
    http://i1341.photobucket.com/albums/...ps2umee3qa.jpg
    Jaguar XJ6C 1977 4.2 (HIF44 carbs) UK RHD ZF4HP22
    Jun 2016
    Thanks Shug. But i already have a wiring diagram attached to the wall in A3 format. This is a help but doesn't indicate where the trouble is. But, step by step i'm getting there. The biggest cuck-ups i found undtill now are loose connectors that fall af by it self. And those are usually in places behind something, like a dash.
    Senior Member rchiv's Avatar
    Feb 2013
    Orpington, Kent
    Hi Ron 62. Sounds like you have a big problem on your hands but all can be sussed. I would suggest you get a circuit tester like this http://www.ebay.co.uk/itm/Draper-Hea...gAAOSwxKtYBpke.
    This will enable you to probe for lives or earths. Connect the lead to either earth and probe for live, or connect to a known live and probe for earth.
    It sounds like you have a number of bad connectors or wires.
    Using the multimeter set to Continuity you can probe wires either side of a connector.
    2006 X Type 2.2d SE Manual Estate. Zircon Blue Champagne/Mocca, F/R Parking sensors, ,Auto Lights, Auto Wipers, Headlight Washers, Sat Nav 2012 update, 17 in Wheels, 122K Mods:- Electric Autofold Mirrors on Locking
    Jun 2016
    Thanks Roger, I'm already in the proces of checking all the connectors.
    Feb 2018
    Delhi
    Jun 2016
    After trying for almost 1 year is gave up. Handed over the car to a recommended specialist (G&G Heinkenszand). They got the car going again. What was thhe case. Some idiot gave the car multiple startblokkers and alarm units (3) and connected them all together so as one blockage was disconnected the second kicked in and so on. On wonder i couldn.t find the source of trouble. G&G removed all the offending alarm devices, gave the car a good service and he, presto. It drives again.
    Jun 2016
    Car still drives beautiful during this summer. Next job, remove two leaking petrol tanks and replace them including faulty pumps. Nice job for this winter why the carbs are away for a good rebuilt.
