hi all,
anyone kno what the symptoms are for a bad fuel pump relay and where this is located,
my jaguar x type 2.0d starts up fine while driving after engine is warm will cut out and wudnt start, as if there is no diesel inside when there is half a tank,
jag man had pluged in computer no fault code recorded, replaced parts : crank shaft sensor and fuel pressure regulator and still doin the same,
engine cuts out with flashing glow plug light, this must be something electrical as it only happens when the engine is warm and sounds like its trying to start when attempted- sounds like theres no fuel inside it,
has any one come across this,.
anyhelp will be appreciated as i have ran out of ideas- can it be the injectors or any thing to do with the pump jag man had done all sorts of test and said the pumps fine as there is power and pressure from it
thanks
thanks
