You need to know how much gas is in the system (weigh it out) you need to check the pressure switch on the inner wing. Swap the relay over and also check the clutch is actually still there. Mine was loose and hanging off.
All the above are common problems with x type ac.
Don't just guess and buy an halfords can of R134a you need to charge by weight.
