Yes, your problems are almost certainly due to low battery. NEVER EVER attempt module reconfiguration/re-programming without an external power supply connected.
Try disconnecting the battery overnight to allow all capacitors in the modules to discharge, and any volatile memory to be lost, then re-connect the ECU before re-connecting the battery. Hook up an external power supply and see if IDS will let you configure the ECU via the 'configure new modules' facility. If this doesn't work, an ECU repair facility should be able to rescue your ECU, or if you can find a second hand replacement with the same part numbers, you can sort the PATS security programming (easy), and also change the VIN, but that's a bit of a chore. I did it a long time ago on an S type that we were just messing about with as it was essentially a scrap car, but I can't remember all the details. I do remember it was easy to change the VIN once we got in to the correct screens etc.
Sorry I can't give more on that at the mo, but will probably have IDS connected to an XK8 later, so will see if I can have a quick look and jog my memory. Will update if any further info gleaned
Regards,
OW
Regards,
OW
