1 - 10 of 10 Posts
Does anyone know what fuse the headlamp washer uses and the location of it?
I’ve replaced the pump and I’m still getting no action from the pump.
fuses are the only thing left
Thanks!!
Try fuse F6 30A in the engine box, it supplies the power wash relay RLY14 in the same box.
So…. The arms are now working they go in and out but no water is coming out does this mean the nozzles could be blocked? If they’re driven by pressure
Definitely.
Discussion Starter · #9 ·
Answering my own question here…..
I figured it out finally…
So they won’t activate again if pushed within 10 minutes however if pushed 4 times and time taken is let’s say 30 minutes they will activate.
this will reset itself if you switch the headlights off then back on again. It’s all working now flushed the system out completely and they’re working perfectly!
Thanks for the help!
Excellent news and thanks for the update.(y)
Reactions: PetA
1 - 10 of 10 Posts
