1 - 20 of 22 Posts
I am in position to buy 16" set of rims from S-Type, tire dimensions 225 55 16.
Can someone please confirm if these rims would fit on my X-Type (is there enough space, etc), and if they are correct dimensions. The difference between these and normal (202) 16" are 6.5j vs 7j.
Picture:
Tire Wheel Automotive tire Tread Synthetic rubber
thanks
The offsets are different but this can be corrected by hub spacers (5mm IIRC, perhaps 10mm). Apart from that they will fit fine.
5mm spacers.
Discussion Starter · #7 ·
Is the tire size correct 225 55 16 for these rims on X-Type? Did I calculated correctly that there will be about 7% dimension error (bigger size)?
Under what term to search for spacers on eBay?
225 55 16 is virtually the same as 225 45 17 which is a standard x type size .
Search for alloy wheel spacers.
Discussion Starter · #9 ·
OK, I have found some. Do I need to get different screws, or anything else?
And what about stiffness? Should I be worried about it.
Why do I need spacers at all? The difference is 7.5mm in rim offset, that doesn't look like something signicirant to me. (I apologize for ignorance in advance.)
Super Moderator
Two reasons:
Without spacers the wheels probably will not clear the front calipers.
The S-Type wheels have a high offset (about 60 mm). The correct offset (ET) for the car design makes sure that the car runs true and loads the bearings, etc. optimally. You could put lower offset wheels on a car to increase the track and make it look "beefier" but it makes a mess of the way the steering feels and responds. Been there with winter wheel purchases where I did not consider the ET match and was mighty pleased when I swapped those wheels back for ones with the correct ET. I would get spacers that make up the difference in the offset (or buy X-Type wheels).
You're welcome.
Out of curiosity I went to check offsets for other Jaguar cars. - They are different for each model.
They never used to be until Ford stuck their nose in and changed everything!
Discussion Starter · #16 ·
Yes, but they also improved production quality and generally changed reliability to (dramatically) better, not to mention that they made an affordable Jaguar: the X-Type we all love.
(And also an S-Type, which is a brilliant, but misunderstood car.)
No arguments from me of those points.
Super Moderator
Aren't a lot of the suspension, brake and wheel components quite related again these days since the introduction of the X202, X350, X250, X150 ... Many parts seem to be interchangeable between similar power/weight versions and wheel offsets seem in a similar ballpark too.
You can always look for Mondeo 3 wheels. exactly the same but much cheaper. I bought 4 x 16 steel wheels for winter use at a tenner a piece from a scrappy. Pristine condition as well.
Tony
1 - 20 of 22 Posts
