Hi , taxed car yesderday and took mum out in the xjs for motherds day test drive. I drove the car of speeds up to about 55 mph and slower speeds of 30 , 40 and less while in traffic. The fans were adjusted and wired for half speed on when the ac compressor is on and full speed at N on the gauge and half speed when pointer to the left of the N . The temp guage was reading to the left of the N to center of the N most of the time with aircon on all the time. When i put my food down up hill the guage reads to the right side of the N and and does not go any higher . So most of the time the temp is middle of the N or less when at 50 mph on a flat road so looks ok so far . On cold start the temp of the top hoses are not what i would expect as when looking at engine from drivers seat the right hand stat / top hose heats up well before the left hand top hose starts to get warm. I would said this was wrong and think i should also replace the stats and wonder if and better quality stats are available like stainless etc but is so are they the same spec ? Car is a 6.0l so think both stats should be 88deg .
So what do you think as the left stat does open ok later so not sure if its faulty or normal ? Do these engine temps increase slightly to the right of N when driven harder ? ps next job is to sort thr squeak from the gear box mounting as apart from that its great
