1 - 9 of 9 Posts
Hello
Audio on my xtype 2008 with satnav stops playing time to time like for a half a sec and then com back.
Doesn't matter if it is on radio or cd.
Any idea where is the problem? It is pretty anoying.
Thanks for help
Hi and welcome to the forum. How old is your battery as these cars do not like bad ones.
Usually dirty fibre optic connections can cause this.
You need to take each one apart and clean them (blow out dust/dirt etc) and remake them.
One of them is there and another in the fusebox behind the glovebox. Then there are another 4 or 5 in the boot depending on how many ancillaries you have such as sat nav, cd, phone, bluetooth etc.
Problem solved.
It is hard to admit it but i cause this fault.
Lesson learned when you change battery it is good also fasten terminals :D
I went for a quick ride it is ok now
Thanks to rchiv.
Well done :)
1 - 9 of 9 Posts
