Hi Guys. I belive I may well have something wrong with my auto box. I will do my best to describe the problem. The whine appears to be comming from behind the radio as if you are seated in the car and is revs related and not speed related. You can generally hear the whine at lower speeds e.g. town driving about 10mph to 30mph over that then it just gets drowned out with road noise. It seems to go up and down with gear changes which also engine rpms going up and down during gear shifts. I have read on other forums about auto boxes having a hydraulic pump and these have given the same symptoms as I am trying to explain, but I'm not sure if the jaguar gearbox is the same as other manufacturers. Anybody else had similar problems or might know what it could be.
Thanks in advance
