1 - 7 of 7 Posts
Are you sure the jet is blocked?
Stealing a pin from SWMBO sewing box would be enough to clear it....but the last time I had this problem I tracked it to a blocked filter on the pump's inlet....
Hi Tamhay 17, if you could update your signature via the link below and tick the Show Signature box we would know which vehicle to look at.
Some have electric nozzles. Water should come out of both. If you have removed the pipe then try blowing through the jet from the outside. Sometimes a small bit of gunge gets trapped.
My 2.5 had a horizontal slot in a fixed spray nozzle on the bonnet. Non adjustable, just clean it out with a long needle or wire thread as you are doing.
No needle will go in deep enough on mine, too fat.
1 - 7 of 7 Posts
