Hi all,
I need help working out what may be wrong with mty Bluetooth install performed today.
Firstly I'm located in Australia and i own a s type r built August 2003. I ordered a voice module, microphone, phone module and bluetooth module from eurojag. My bluetooth connector under the armrest appears to be a 8 wire connection. The vehicle never had a factory phone fitted and i think that i have been prewired for bluetooth as i have a pse module connection in the boot along with a voice connection in the boot. Once the microphone and the phone module was connrvted i proceeded to plug the bluetooth and expected to be able to pair my phone. When the phone button was pressed the system says Handset In Use Mute and replace handset to continue hands free call or replace handset to end call. I can not get out of this screen. Uncertain as to wether the microphone was working or not i disconnected the phone module and connected the voice module. As soon as i tested the voice module to my surprise the voice module worked fine.
The model no. of the phone module is 2w93-19k350-AC software version is 1.30(As checked in diag mode) and the Bluetooth module 3w83-14b409-AC. I have read on an x type TSB the phone module software needs to be version 4.0 in order to work correctly. Can anybody clarify if their module is the same software as mine and is working with bluetooth. Diag mode can be accessed by pressing the am/fm button and the eject button at the same time. From the you need to select the the eject and mix buttons to cycle through each modules software version. my navigation software is 1.22. Any clues would be a great help.
regards
Joe
regards
Joe
