Broken Wheel Nut/Lug Nut Removal
plaviator
21
Jurassicengineering, do you still have any of these removal tools, I’m in need ASAP.
Hello,
I had one made for me at a local engineering company here in Poland.
Sorry that I cannot be of more help.
Regards, Michael
Acedesigns
3
Shotts
Wheel removal tool
hi thanks for the reply
would you sell it too me as I need to get my brakes done ASAP.
maz
Hello,
Regards, Michael
plaviator
21
maz
I could lend it to you but is would probably take two weeks to get there. I could probably find the drawing that it was made to and then you could get one made
Acedesigns
3
Shotts
Broken wheel nut
thanks very much
could you send it to the following address
177 mill road
Allanton ML75DD
UK
if you could send it ASAP and I will obviously reimburse you for postage, so if you could send it express fast delivery.
I have 3 nuts broken off, shocking how bad they are.
also send with it your return address.
Very much appreciated.
maz
plaviator
21
If you give me your email address I will send the drawing.
The problem is that with this virus, Polish borders are closed which includes airmail so I think that it would take ages to get to you.
I'm sure that you could get it made quickly at the moment at a small engineering works.
plaviator
21
I will check on Monday when the post office is open and find out about sending it to you but in the meantime let me have your email address and I will send you the drawing. Thank you for the address, I will also need your name.
This is for an S Type?
Michael
liverpool39
3
After a lot f reading on this sheared wheel nut issue I decided to go with a 17mm hole saw with a 14mm internal cutting dimension with no drill bit in the arbor,which took 10 minutes.Then removed the other nuts.And finally used a pair of stilsons to remove the last of the hub nut after wheel was removed.All in all 15 minute job.
RaymondPetersen
1
Oklahoma City Oklahoma USA
I was trying to get that tool made found a shop wants $175.00 to make so I was thinking of doing the same thing you did but I am going to drill 6 small holes after making a mark with the arbor and take two pieces of tubing to help hold the arbor centered The outer piece of tubing will have about 3 rounds of tape to protect the chrome. I have been trying to get that tool made for days and decided to go with the arbor and was just reading the forum today and only looked at page 2 today and saw your idea which confirms what I was planning to do should work I am glad I found your post Thank You Also should say My friend did all of the work looking for someone to build tool He deserves a lot of praise too
