Clear a warning
916 Views 3 Replies 3 Participants Last post by  Ian D
I've just changed the low windscreen washer sensor but it still appears on my dash.
How to I clear the codes or remove the warning please ?
1 - 4 of 4 Posts
With a Code Reader. Just bought a Memoscan U581 on recommendation from the forum, this should erase warning lights.
You won't be able to remove the low windscreen fluid warning with a code reader. It may be a wiring fault that you have there. Most readers just remove engine codes.
1 - 4 of 4 Posts
