Hi Micky,
As far as I am aware, and unless somebody knows different, the clutch
is hydraulic operated and does not have a cable for any adjustment.
The clutch slave cylinder is fed by the same master cylinder that
operates the brakes, located near the bulkhead in the engine bay.
Sounds to me like, when you had the new clutch fitted either the
clutch plate was not centralised, or the clutch operating arm is not
sat in its correct place.
