1 - 4 of 4 Posts
my obd2 shows p1111 as the code the computer is throwing off , i'm wondering if this is the suspension default code ,cause the suspension default has been coming on the information cluster. was wondering if theres site read jaguar codes , thanks in advance.
Code P1111 is nothing to worry about, it means everything is ok with no faults.
I think it means a fault occurred on a journey but did not put the warning light on,maybe check through the other systems to see if you have a fault code on one of them,mine has fault codes but does not affect it or put the light on
1 - 4 of 4 Posts
