My car, a 2005 X-Type 2.0D estate which I've owned for ten years now has developed a fault. It's displaying a red warning light and when you press the trip button alternates between odometer and "Fuel Computer Data Error". Turning the key to the start position does nothing. Up to now the car has been working just fine apart from an intermittent glitch in the message centre where the display cycles its modes randomly. This started around a year ago and was more an annoyance rather than an problem. I replaced the indicator stalk with a used item, no change. I also replace the cable to the dash, this also made no difference.
A few weeks ago I took the car to top up the tank and parked it up for a week. I now find it dead.
Things checked:
Things checked:
- Battery has been charged from time to time since covid hit and is fairly new.
- I've disconnected the battery for a day.
- Checked all the plugs etc from when I was working on the indicator stalk.
- Done a gauge test, tank reports full which is correct. I've also tested the fuel sender and it's reading 163 Ohms which is correct for a full tank.
- Checked all fuses under the bonnet.
- Check fuel pump fuse in the cabin.
- ODB2 scanner reports no codes
