H Dodsy. As regards the timing tensioners the X350 is clear of the nasty plastic ones used on the older X308 model up to july 2000. As towards the difference in the XJ8 and Sovereign I'm not sure what the spec difference is but the use of the Sovereign badge was more common on the Daimler versions of the car and was usually a bit higher spec than the Jag.
