Hi all, do you own a late 2002 onwards 3.0, if yes can you let me know your normal running temp by useing the engineering test mode dash read out?
If you don't know how, read below-
Push and hold in the button on the left indicator stalk, then start engine, it will say test mode where your miles would be.
Now, use the same button to advance thru all the modalities until you come to 'TEMP IN 765' which is coolant temp 76.5c.
Thanks Simon.
Thanks Simon.
