1 - 4 of 4 Posts
Hi All,
Just noticed the mirrors are starting to make a dry rubbing noise when setting the alarm, I assume the mechanism needs a little lube?
Is there an easy way to remove enough of the assembly to allow some grease to be sprayed in........
regards
No need to remove anything Bill. Get some silicon spray and spray in behind the mirror and also in the pivot point, should ease things up.
1 - 4 of 4 Posts
