You have a couple of options.
First, persist.
You have to jack it up high enough, support the hub up on an axle stand
(you can raise it with a jack slightly first, but replace the hub nut, hand tight first ),
remove the bolt and nut out of the lower ball joint,
then either tap the wishbone down with a block of wood or wrap a chain and bar around the wishbone and pull it down, for leverage.
Failing that, loosen the subframe that side,
there's a bolt at the front inbetween the front part of the undertray and the wheel arch liner,
and one at the back with a retaining plate around it.
Lowering the subframe will give you more room to lower too ( if that makes sense)
I've never had trouble popping that balljoint even without lowering the subframe, but it is a tight squeeze.
First, persist.
