My column adjuster isn't working at all. No response from the switch at all.
I've checked fuse F19 in the drivers footwell fusebox which the handbook tells me is the one for the adjuster motor but that is intact.
When I got the car the electric seats were a little iffy but following the advice from here I replaced the battery with a Varta H3 Silver and was hoping that would sort out the column too.
Unfortunately, although it did have the desired effect on the seats which now work perfectly the column adjuster is still not functional.
My car is a 2002.5 3.0 SE
Can anyone suggest what I should look for next?
