adjust dimmer switch on steering column
I've tried that but no joy!adjust dimmer switch on steering column
Thanks, I will have a look tomorrow. Cheers!sounds like a dodgy earth, have you looked at the condition of the ground points under the bonnet behind the headlights, dome head nuts holding black earth ring connectors, try cleaning these up and inspect the headlight bulbs.
