1 - 12 of 12 Posts
I knew that in the event of a remote failure you could unlock the car via the key and the passenger side - but do I deduce that this doesn't unlock the boot and you have to pull the rear number plate off? Found this photo online... and yes I'd like a green one :)
How can you unlock the car via the passenger side ?
on U.K. cars this is where the emergency key blade fits. There is a cover on the handle that comes off to reveal the lock.
Administrator
Boot lock is visible with USA/Japan style square plates, with UK rectangle ones it’s covered and so yes that’s how you get in when the power is gone to the bootlid.
...but do I deduce that this doesn't unlock the boot and you have to pull the rear number plate off? Found this photo online... and yes I'd like a green one :)
My car is Japanese spec so I don't need to remove the rear number plate but assuming that you have power, there is also a handy button on the dash that pops the boot :)
I fitted a number plate surround which I can remove with no tools so I can access the emergency lock behind, otherwise how are you going to get to this without a screwdriver to remove the number plate first?
I've attached my rear plate with high-strength velcro dots.
1 - 12 of 12 Posts
