Catalytic converter system efficiency below threshold – bank 2, means HO2 Sensor disconnected, HO2 Sensor to ECM wiring fault, HO2 Sensor heater to ECM wiring fault HO2 Sensor heater failure Upstream HO2 Sensor failure Downstream HO2 Sensor failure Catalyst failure, I expect it is the sensor needs changing, or it could be the MAF but would change the sensor first
