Hi
ive recently notice engine oil leak from a round pas pump area on the top of engine does the pas pump bolt direct on to the block and if so is there a gasket that can be replaced .i have had car for 4 yrs and engine has always been dry had a new clutch fitted about 4 weeks ago is the pas pump removed during clutch replacement .also car only leaks when not running start car and oil leak stops any ideas or pointers would be much appreciated
