My 2006 car suffers from the same creaking doors. I tried a variety of different chemicals - made it better, but didn't really solve it. It seems the door check straps wear quickly for some reason.
The noise varies with temperature , but still annoying.
In the end, I bought some new check straps from Jaguar - they are about £25 each and fairly easy to fit. I can dig out the part number if you want - worth noting that the part has been altered a number of times, so hopefully they've fixed the wearing issue!
My window also squeaked, but since washing the car with Turtlewax "wash and wax", the noise has gone. I presume the wax has lubed the window rubber/glass. When I've de-swirled the paintwork, I was going to switch to Meguiars, but not so sure now!
Mine also had a whistling from the fan. The climate control filter was pretty clogged, and since I've replaced it and cleaned out the mound of dead leaves from the housing, it's been fine.
I've still got a million other jobs to do, but these were (Borat voice) "Great Success!"
