1 - 3 of 3 Posts
Hi folks,
oil light has started flickering on my 54 X-type diesel estate, causing me wild panic and off to nearest Kwik-Fit for oil change. Exactly the same oil light issue after the work was done. Car was sitting in drive for three weeks while on holiday, then working away from home, never had issue with it before. Seems to be a common problem, but hoping I can sort it myself if I can track down where the sensor is.
Can some one point me in the right direction?
Thanks in advance. :0)
Ken
G
Quite a comon problem and easy to fix. Oil pressure sensor (from memory) is by the oil filter - front left of the engine, You need to remove the "under-tray" to get to it. It's also not expensive - I seem to remember paying about £20.00 a couple of years ago.
1 - 3 of 3 Posts
