I have been doing some searching on the net regarding Forstner bits and I thought I would share what I have found as others might find it useful. I have almost made up my mind as which ones to purchase, but as they cannot be said to be cheap by any stretch of the imagination, I thought I would also put it out there, in case any members have some advice that would be interesting and valuable while I am still making up my mind.
I do have a couple of sets of these bits already, but they are obviously cheap and of poor quality, as each time I have gone to use them, the outcome has either left me wanting, or has just about done the job with a struggle and a poor finish.
I hasten to add I am very much a DIYer, and am likely to use the bits occasionally, but having said that, if I had a decent set that worked efficiently, maybe things would change and I would use them far more often.
So here we go with the bits of info I have found out thus far, starting with the basics and not going into the fancy Forstner bits like tungsten carbide etc., I found there are the generally accepted 3 blade/rim types:
1) Sawtooth Rims
2) Continuous Rims
3 Wavy Rims
It is the Wavy Rim that seems to have taken my fancy and this is the idea of an Austrian company called Fisch that have been making drill bits for over 75 years.
FISCH-Tools — Ultimate drilling solutions
They developed the wavy rim on a forged drill head which is said to enable them to be exceptionally sharp and stay that way for much longer periods of use. The wavy rim enables the bit to remain cooler for longer and also to be run at faster speeds in the drill, and it is the cooler temperatures, that helps to maintain both the sharpness and longevity, as I understand it.
Their latest Forstner Wavy Rim bit from Fisch is their 'BLACK SHARK Pro', which is supposedly even quicker, more aggressive and sharper than the others and the link to the article below gives a lot more detail on this Forstner bit:
Fisch Black Shark Forstner Bits Review - Tools in Action
1) Sawtooth Rims
2) Continuous Rims
3 Wavy Rims
