Front brake discs
Piousx
343
30
28
Guildford
I replaced my discs and pads (Berkshire Jag Components but I can't remember which brand - maybe TRW) about 18 months ago and have done 14k miles since. I replaced them because they were juddering and all has been well since but the judder is back. Is it best to spend the least amount of money on discs as they are all likely to warp or a lot of money as the more expensive ones are made of something that will last longer? Euro Car Parts are £51.14 for a pair of Eicher discs, Rimmers are £233.24 for OEM.
Many thanks - Chris
JimC64
Active member
13,645
9,240
203
Many thanks - Chris
Chris, are you sure its the discs?
Checked for sticking calipers etc, all else all A ok?
Piousx
343
30
28
Guildford
Hi Jim,
Truthfully I've only just noticed it creeping back in and it's too bloomin cold to stand outside and take the wheels off so I'm doing the chair based tasks first. Just sounding out the group on their approach to discs.
Cheers Chris
MrKis
Active member
5,715
1,989
148
Manchester UK
As Jim says plus worn suspension components. You’d have to check the discs for runout.
Although, Jaguars do seem to suffer from brake judder more than most.
Have a good look at the discs. Can you see shadows or outlines of the brake pads?
I think any disc is susceptible to damage causing judder. But some have said the OEM discs last a bit better.
JimC64
Active member
13,645
9,240
203
Hi Jim,
Cheers Chris
Had something similar on my X358 some years ago Chris
Changed out everything......discs n pads, came back after 4 or 5k miles
Front wishbones looked suspect, they got done too, were coming due anyway
Wheels as I thought I had a wobble ( one of them had a very good crack repair )
Turned out to be a sticking caliper
After you've been out for a run and park up, just check each wheel, see if one is noticeably hotter than the other.......worth checking as it may be your issue
JimboV8
Active member
I Have Donated !
19,483
9,552
243
Any unevenness in pad wear may reveal a sticking calliper.
JimC64
Active member
13,645
9,240
203
Chris, here is some of my issues that seem similar on my 358, probably around half way through
If you read onwards ( skipping the other stuff ) you'll see where I got too
Worth ruling out as if you stick new pads and discs on, the problem will simply come back sooner rather than later
