1 - 10 of 10 Posts
Hi All.
I am an X358 & X351 owner but a friend asked me for help today with his fuel filler neck.
He was carrying a large container in his boot and had to brake harshly when turning. The container slid and banged the inside of the boot and when he went to fill the car he noticed that the feller neck was blocked by a metal plate.
I used the tool on my own car when I stupidly tried to fill with petrol and a flap with a hole in the centre stopped came across the neck. The hole allowed the insertion of the reset tool but on this XE the flap is solid so the tool cannot be inserted..
Has anyone came across this one before and what was the fix? I plugged my SDD in but his car was not supported.
TIA.
John F
It sounds like you may have this problem.
Exactly the problem. Will probably need SDD but my version does not have his car details. Perhaps a hard Reset might do the job. I would try if it was my own car but not on someones elses.
From what I understood from the other thread. They said something had become loose and it jammed the flap.
You may have to dismantle the flap.
It seems to be part of the cap.
There are pictures from Topix with a description in the thread.
Reactions: JimC64
I would start by removing the the surround and looking to see if there is any thing has caused the problem.
As it not your car though it may be better to suggest that he goes to an independent jaguar specialist
Reactions: John9285
That looks simply like the misfuelling protection device. 20s to fix, just follow the instructions in the manual. The tool will be in the foam pack near the battery.
1 - 10 of 10 Posts
