1 - 17 of 17 Posts
So my 2.2d has had a full blank for 4 months now, and had the check engine light on the whole time, which was expected, except today it went off whilst driving......i wonder why
Probably blown a hole in your blanking plate :-D
It does if you used a tin or aluminium plate rather than a steel one. The hot gasses will eventually bore right through it.
Tony
its a 3mm stainless steel plate, so it shouldnt have gone through right?
Discussion Starter · #7 ·
No, a 3mm stainless is quiet safe.
Your computer has probably reset itself.
Tony
its weird that its scarier with the light off then when its on XD XD XD
im gonna whip it off tonight to make sure
it would be weird that its been on everyday for the last 4 months and just chosen to reset.
It's a Jag. They do funny things.
Just check all of your fluids etc and if you have one, plug in a code reader and look at the live readings from the engine. Also you may find there is no fault code anymore in which case you can stop worrying.
Tony
I thought the 2.2's needed a hole in the plate anyway?
Perhaps the bulb has given up the ghost... is it designed to be on for months?
Discussion Starter · #12 ·
the light has come back on, im guessing the car just reset the code and took a while to re-register the fault, took the blanking plate out and it hasn't melted at all.
its probably not designed to be on permanently, but it causes no harm :)
and i feel its much more benificial to have the blanking plate full and have the light on then to fit one with a hole in it.
Fair enough, but my concern would be that the always-on light could mask another (possibly more serious) fault. Probably a good idea to check for codes regularly.
Discussion Starter · #14 ·
yes it could, which is why i code scan before and after every journey. I will be purchasing the EGR simulator to turn the light off for good soon,
Discussion Starter · #15 ·
Update to the Missing EML, the light went off again three days ago, and it hasn't come back, I've checked the EGR Blank and its not blown through. I've checked all the pipes for splits, and I've checked all the jubilee clips are tight.
the only thing i can think is that the adaptive mapping must have adjusted to believe that the airflow is standard, so no longer throws an error.
it only took 6 months of being on for this to happen.
I run a full blank on mine. Occasionally the "Low flow" warning light puts in an appearance, I reset it and it goes away..
Discussion Starter · #17 ·
well mine was on solid since i put the blank on, the it went off once for a day, and i panicked, then it came back on for a fortnight, then its gone off again and stayed off. so i have a feeling it might not come back on again.
1 - 17 of 17 Posts
