Don’t I know it, all the show with none of the go!!Getting close to V8 mpg there Glenn!
That’s what happens I guess when you let your DPF get too full, it just dumps fuel anywhere but the pistons.
A simple truth right there....Unfortunately, no one seems to have the answer to this problem.
If the XJ was a mainstream car then I bet a solution would have been found.
Hope you're having a good Christmas Glenn.Merry Christmas everyone, big day been and gone, hopefully you all got spoilt.
Me, I got new polishing pads for my DA, a box full of Microfiber cloths along with the usual T shirts and other similar “your no longer a kid” stuff.
I also got a Firestick for the car and a natty T shirt.
My new phone contract has unlimited data so no need to worry about tethering for too long now.
I had no idea you could plug in a firestickMerry Christmas everyone, big day been and gone, hopefully you all got spoilt.
I have a spare one at home so that will be going into the car tomorrow![]()
Sounds like you got spoilt Glenn.Merry Christmas everyone, big day been and gone, hopefully you all got spoilt.
I had thought about it ages ago, Marc has one in his and it was on my to-do list, Janis obviously pays more attention to things I say than the other way round…. lolHope you're having a good Christmas Glenn.
Well done on the Firestick. Just did mine last week "because I could". I do have 40GB of data per month on my 18 month 4G 3 sim, so may atleast try and use some of it![]()
I’m not sure how good it’ll be on the move, guess if you hit data black-spots it’ll give issues, but certainly adds to options for the grandkids.I had no idea you could plug in a firestick
I’m not sure, I’ll need to ask Janis, it’s not one I’d seen before, so pretty impressed with it.Cracking shirt - is that custom made, or generally available?
Yeah, pretty impressed with it. Janis seems to know me better than I thought. lolSounds like you got spoilt Glenn.
T shirt looks great
I would have been too!... pretty impressed with it.
Better make the most of it while I still can...![]()
"Rosso" - My 2018MY XF S 3.0D Ownership Thread
Yeah, thats what they’ll do… Not holding my breath on that one though… I don't know which carrier JLR use in the UK, but Vodafone are turning off 3G end of by December 2023, but in phases so some areas go within a few months :(...www.jaguarforum.com
Hint: when someone posts a link to another thread on the forum, don't read the preview, click on the link to go to the actual intended target post.Better make the most of it while I still can...
I did read through the post... Did I miss something?Hint: when someone posts a link to another thread on the forum, don't read the preview, click on the link to go to the actual intended target post.
It was about using a FireStick.I did read through the post... Did I miss something?
Yes, I meant that I can use the firestick to stream with my 3G. As I am with Three and they will switch off 3G by end of 2024. Which means I should be okay to use the firestick and stream all the way into 2024 at some point and then the streaming will stop when the 3G is switched off.It was about using a FireStick.
(... which was a bit more relevant to the conversation than the "turning off 3G" content of the preview)
Never used 3G to stream? I wonder how good this would actually be with the high quality these things try to run at?Yes, I meant that I can use the firestick to stream with my 3G. As I am with Three and they will switch off 3G by end of 2024. Which means I should be okay to use the firestick and stream all the way into 2024 at some point and then the streaming will stop when the 3G is switched off.
In short, my firestick will be good well into 2024 fingers crossed
