Gear Box Fault, Parking Break Problem, DSC not working.
gt2013
60
Hampshifre
I never use the parking break as I am very unhappy of clamping the pads on a very hot disc. Several reports of distorting discs around.
On the diagnostics not sure that the dealer version (ILS) is that open for them to access all of the facilities/options. Whereas it seems that Autologic is able to get all the readings as well as being able to edit the config file.
GeoffR
Active member
1,712
7
33
South Bucks
I never use the parking brake as I am very unhappy of clamping the pads on a very hot disc. Several reports of distorting discs around.
If you don't use the park brake, I assume that you hold the vehicle using the foot brake?
There is absolutely no difference between holding the car on the foot brake and using the foot brake. They use the same pads on the same disc. The only difference is that the park brake operates only on the rear wheels.
paulkebab
1,528
2
Great Harwood, Lancashire
On the Jags with a separate parkbrake caliper (mine included) I would rather use the parkbrake on a hot disc as the pads are about a third the size of the main caliper pads.
rog8811
60
Surrey
I only turn up here on the forum when I have a problem, fitting my dash cam was the problem. I now know why my Cigar lighter doesn't work even though I stuck a fuse in for it! I also now know that the rear one does work and turns off on locking the car, perfect....other than the fact that the cable is too short :( ....Ebay here I come!
Anyway, the forum has sorted my problem again, keep up the good work.
chr1s23
251
West Midlands
I'm with Wilf on this one. Whenever you start to get weird messages, a change of battery is always the first port of call. This forum is littered with the phrase 'change the battery'!!
Me too! I'm with Wilf and Reevo. Jumped in the car the other day and clunk, nowt! Battery shot. Worked perfect the day before, no funny messages as a warning. I have found that the parking brake emergency release does not work if the battery is dead! Not much help with car reversed in the garage!
You are lucky, heed the 'funny' warning messages and change the battery while you can still start it.
D3GGY
455
1
This is direct from a technical bulletin and points to the brake pedal (stop lamp) switch. It fixed the issue on my last XF
SECTION: 206-05
Parking Brake Warning Lamp Illuminated / Parking Brake Fault MessageDisplayed
AFFECTED VEHICLE RANGE:
XF (X250)Model Year:VIN:
2010-2014R47154-U34501
Engine:
Engine:
GTDi 2.0L PetrolTD4 2.2L DieselTDV6 3.0L DieselV6 S/C 3.0L PetrolV8 5.0L Petrol
V8 S/C 5.0L Petrol
GTDi 2.0L PetrolTDV6 3.0L DieselV6 S/C 3.0L PetrolV8 5.0L Petrol
V8 S/C 5.0L Petrol
XK Range (X150)
Model Year:
2010-2015VIN: B32964-B55731
XJ Range (X351)
Model Year:VIN:
MARKETS:
All
2010-2014V00001-V70683
2012 OnwardsT00001-T02140
CONDITION SUMMARY:
Situation: A customer complaint of various fault warnings displayed on the instrument cluster which mayinclude
• Gearbox fault
• Parking brake fault
• Engine management light
• Dynamic stability control fault
Suggested Customer Concern Code GA1.
Cause:
A loss of communication between the powertrain control module (PCM) and the parking brake module.Action: Should a customer express concern, follow the Service Instruction outlined below.
PARTS:
C2D41993 Parking brake module Quantity: 1
TOOLS:
No Tools Required
WARRANTY:
[COLOR=rgb(5.882353%, 5.882353%, 66.666670%)]NOTE: Repair procedures are under constant review, and therefore times are subject to change;those quoted here must be taken as guidance only. Always refer to TOPIx to obtain the latest repair[/COLOR]
20/10/2015 22:27
NOTE: DDW requires the use of causal part numbers. Labor only claims must show the causalpart number with a quantity of zero.
DESCRIPTION
SRO
TIME(HOURS)
CONDITIONCODE
CAUSALPART
Parking brake module renew XF
70.35.47
0.5
4
C2D41993
Parking brake module renew XJ
70.35.47
0.3
4
C2D41993
Parking brake module renew XK Couple
70.35.47
0.4
4
C2D41993
Parking brake module renew XKCabriolet
70.35.47
0.8
4
C2D41993
Stop lamp switch renew XF
86.65.51
0.2
4
C2P14525
Stop lamp switch renew XJ
86.65.51
0.2
4
C2P14525
Stop lamp switch renew XK
70.35.01.01
0.2
4
C2P14525
NOTE: Normal Warranty procedures apply.
SERVICE INSTRUCTION:
1Connect the Jaguar approved battery support unit/power supply.
2Connect SDD to the vehicle and begin a new diagnostic session, by reading the vehicle identification number for
the current vehicle and initiating the data collect sequence.
3Read the diagnostic trouble code memory. If the diagnostic trouble codes U0401-00 and P1571-64 are loggedwith the same time stamp then install a new parking brake module (see TOPIx Workshop Manual section 206-00), then remove and install the existing stop lamp switch. (see TOPIx Workshop Manual section 310-03 forXK, 417-01 for all other models).
4If the fault code P1571-64 or any other diagnostic trouble codes are logged in the parking brake control modulewithout U0401-00 at the same time stamp the remove and install the existing stop lamp switch (see TOPIxWorkshop Manual section 310-03 for XK, 417-01 for all other models).
5When all tasks are complete and the diagnostic trouble code memory is cleared, exit the current session byselecting the Session tab and then selecting the Close Session option.
6Disconnect SDD and the battery support unit/power supply.
