1 - 5 of 5 Posts
Hi All;
After a very short moment of happiness whilst I fixed the parking sensor (thanks fro your help/support), the fuel gauge is reporting zero fuel in the tank but the tank is 80% full - I know because I filled it :)
Is it possible that I have damaged the fuel gauge wiring whilst trying to fix the rear PDC sensor? I literally removed the diffuser's 4 plastic screws and inserted my arm between the diffuser and the rear bumper and replaced the PDC sensor, nothing else was touched!!
Could this be just coincidence?
Anyway, is there a simple solution, is this a faulty fuel sensor or do I have to replace the fuel tank or the fuel pump?
Thanks for your help again
Lucio
i would try disconnecting the battery for half an hour and see if that fixes it.
Hi, if that doesn't work I believe that it is fairly easy to access the fuel sender unit, just remove the rear seat squab and there is an access panel above the sender unit. Phil
1 - 5 of 5 Posts
