Macca, you will have to be more specific on what seals you mean, are they the ones the glass slides up and down in, or the seal on the outside of the door that pushes against the glass?
I've just posted how to change the microswitch in the J-gate to stop the clicking - here. http://www.jaguarforum.co.uk/f26/how-repair-annoying-click-auto-j-gate-pictures-54397.htmlHowdy Clive, learning something new again. Loads of little jobs to do; waste seal replacement, drivers window guide/seal replacement, J-gate replacement (clicking like mad!) and a new handbrake gaiter to fit. All ideal for a Sunday.
You wouldn't happen to have the Jaguar part number for the seal perhaps? I need to replace both of my rear ones (when I get the car) and a part number would be useful, also how much the dealers charged you if you can?I know this has been talked through, but do have a question. Just going through all the niggles on the car. I have bought a rear near side waist / waste seal for my x-type from the local Jag dealership. I've took the old bubbled one off and fitted the new one, however, the front bit (after the window / next to front door) does sit properly, its kinda raised a little and doesn't meet the door frame properly. Looking at the door frame there is a little piece of metal almost like a clip on the bottom, and on the new seal is a piece of rubber that is almost parallel to the afore mentioned metal clip, This bit of rubber isn't there on the old one.... Any ideas?
Thanks for that mate much appreciated. Just had a look on the web and the offside one if anybody needs the number is C2S427377.the N/S one is C2S42738, not sure if O/S is different as i only bought the N/S one.... Cost was £19 + VAT
